CAMSHAFT replacement
Old Aug 27, 2009 | 04:55 PM
02_CiViC_LX's Avatar
Default CAMSHAFT replacement
I bought my k20 from a junkyard and am going to rebuild it from the ground up. I see so many different camshafts on the market and the stages they have. If I wanted to go with stage 3 camshafts what would that mean, and what else would I have to replace (ie crankshaft, flywheel)? My goal is to get this puppy to 260 over 2 years. Also, what is a great brand? I know this aint cheap but quality is better anyday over quantity when it comes to motors in my opinion. So lay it on me.
Old Aug 27, 2009 | 06:06 PM
hamorhead's Avatar
well there are no set stages between companies so you go by the specs not the stage number
and is this daily driven or a track car cuz a stage "3" wont have a very good idle for a DD
Old Aug 27, 2009 | 08:32 PM
This is going to be a daily driver. What would be best than?
Old Aug 28, 2009 | 12:05 PM
I wouldn't recommend anything above stage 2 for DD. If you do end up going stage 2, I would suggest some upgraded valve springs and retainers.
Also, keep in mind when you do start adding upgrades such as these, you'll need to worry about tuning, which isn't cheap for K series.
Old Aug 28, 2009 | 04:57 PM
hamorhead's Avatar
^yea get stage 2 cams, springs, retainers, P&P head, port match intake mani, bigger TB
and idk much about the bottom end if your getting into that so ill let someone else tell you bout that
and of course I/H/E
and then tune it
Old Aug 28, 2009 | 08:33 PM
and of course I/H/E
and then tune it
Ok then. I know for sure to go with Stage 2 Cams and springs and retainers. what is I/H/E. I know that after those upgrades I have to tune it. The D17A1 is fine. It's great, but it doesnt give me the power I want. Plus, K20's have more parts readily available, D17A1 dont. What do I have to do on the bottom end?
Old Aug 28, 2009 | 10:13 PM
... iintake/header/exhaust.....
Hailchristian
Nov 25, 2007 04:38 PM
trixmotorsports
Mar 6, 2006 11:07 AM
schweigel
Jun 11, 2005 08:38 AM
wimreems
Mar 19, 2005 10:09 PM
OrangeCivic
Jun 29, 2004 05:05 PM
