Compression
Old Sep 25, 2007 | 07:20 AM
D17Punk's Avatar
Default Compression
If im staying N/A and i put in 8.8:1 compression pistons is that fine? or should i have a higher compression if im staying N/A?
Old Sep 25, 2007 | 08:51 AM
Lost's Avatar
Default RE: Compression
this is for a d17? 8.8:1 is like turbo pistons, get some 11.5:1 and run high octane.
Old Sep 25, 2007 | 09:26 AM
riceburner700's Avatar
8.8 would probably lower than stock and you will loose power, run 11+
Old Sep 25, 2007 | 12:02 PM
D17Punk's Avatar
do you know if they make high compression? stock right now is 9.5:1 and i have only found lower but i was planning on getting a new camshaft, a new cam gear, and valve springs and retainers, new valves. I know its going to be a lot of money, its a long term project for me. Is there anything else i can/should upgrade along with that?
chones2083
Jun 2, 2005 06:48 PM
nachoman
May 23, 2005 02:37 PM
aquessada
Feb 21, 2005 03:00 PM
Dickie
Feb 10, 2005 06:24 PM
Blackhatch124
Nov 10, 2004 08:20 PM
