D15B swap
Old Jan 28, 2007 | 07:39 PM
Fiirkan's Avatar
Default RE: D15B swap
Sorry don't have a deffinate answer for that , the intake yes, throttle body is the same as the one on the D16Z6 and the B7 and the D15B. so i would even bother with that unless you are going to swap for say a Skunk2 I/M then maybe get the throttle body. as for the Camgears, you only really need those if you put in different cam's in
Old Jan 28, 2007 | 09:46 PM
Kedawei's Avatar
For a JDM D15B, buy D16Z6 parts. The motors are very, very similar.
Old Jan 28, 2007 | 10:30 PM
ProjectGSR's Avatar
^ haah "very, very similar" or the same? Cause "similar" isnt a good word to use when talking engines...
Old Jan 28, 2007 | 10:38 PM
Fiirkan's Avatar
the only real difference is the internals of the block
Old Jan 29, 2007 | 07:41 AM
bigmikew1's Avatar
and will it be hard changing my car to v-tec?
i think i saw a thread about that. ill search and see.
Old Jan 29, 2007 | 03:30 PM
Kedawei's Avatar
ORIGINAL: ProjectGSR
Everything but the crank and pistons are the same.
Old Jan 29, 2007 | 06:37 PM
Nail I3unny's Avatar
ORIGINAL: Fiirkan
as for the Camgears...
he only needs one
liketim said, the only real case in which it would be worth buying a cam gear is if you are already running some pretty hefty mods, including avery lumpy cam.
Old Jan 29, 2007 | 07:24 PM
Fiirkan's Avatar
ORIGINAL: Nail I3unny
ORIGINAL: Fiirkan
he only needs one
like tim said, the only real case in which it would be worth buying a cam gear is if you are already running some pretty hefty mods, including a very lumpy cam.
whoops my bad. consider that a typo
Old Jan 30, 2007 | 08:57 PM
ProjectGSR's Avatar
Hey fiirk, do you know if you can use your d15b7 trany on a JDM vtec d15???
Booger
EK Swaps
Aug 9, 2011 10:11 PM
smokingemcee
Nov 18, 2006 09:02 AM
Cody_Bell97
EK Swaps
Oct 25, 2006 09:32 PM
trex87
Apr 10, 2006 09:58 PM
93civicex
EG Swaps
Sep 18, 2005 08:06 PM
