d15b6 rpm
Old Jan 20, 2007 | 11:29 PM
finalimpact's Avatar
Default RE: d15b6 rpm
ORIGINAL: Kedawei
Given that peak hp occurs at 4500rpm, that is surprising final.
when bolting on an si head with the si intake manifold and ecu..........this is what makes it a cheap yet potent set up. not only does the headswap allow for better breathing but it raises the compression ratio as well. although the b6 pistons are only notched for an 8 valve head so proper cam timing is crucial to keeping from bending any valves. this also does not allow you to run an aftermarket cam.
Old Jan 22, 2007 | 11:48 PM
Kedawei's Avatar
Ah, missed the part about the head/IM/ecu. [8D]
91crx_97cx
Dec 14, 2007 02:22 PM
joker96
Feb 26, 2007 07:22 PM
Shaved96
Jun 11, 2005 10:33 PM
edunnett
Oct 19, 2004 05:54 PM
importmech
Oct 14, 2004 09:25 PM
