D16A6 head on D15B7 ?
Old Jul 25, 2008 | 06:05 PM
Mr.Whiteside's Avatar
Default D16A6 head on D15B7 ?
Im wondering if this will work and if it would make a difference at all?
Old Jul 26, 2008 | 12:09 AM
bcrichguitars's Avatar
Default RE: D16A6 head on D15B7 ?
D15B7=[ul][*]Power: 105hp (78kW) @ 6200 rpm & 98 ft·lbf @ 3800 rpm
D16A6=[*]Power: 115hp (86kW) @ 5600 rpm & 100 ft·lbf @ 3,800 rpm, redline 7200 rpm (USA)[/ul]
Old Jul 26, 2008 | 09:56 AM
should work
Old Jul 26, 2008 | 10:37 PM
ORIGINAL: trustdestruction
should work
But will it gain any power from just the head?
Old Jul 26, 2008 | 10:58 PM
ORIGINAL: bcrichguitars
D15B7=[ul][*]Power : 105 hp (78 kW) @ 6200 rpm & 98 ft·lbf @ 3800 rpm
D16A6=[*]Power : 115 hp (86 kW) @ 5600 rpm & 100 ft·lbf @ 3,800 rpm, redline 7200 rpm (USA)[/ul]
this isn't right
i know for a fact the D15B7 has 102hp at the crank, and the D16A6 has 108hp
i think someone messed with wikipedia
so you'd have a net gain of around 6hp, making it not worth it
Old Jul 27, 2008 | 10:58 PM
riceburner700's Avatar
why swap out whole heads when you can just take the A6 cam and throw it into the b7, same ports and everything just the a6 has a more aggressive cam. will work %100 fine
Old Jul 29, 2008 | 01:08 PM
newcivicguy's Avatar
awesome, I'll be doing that as well to mine
Old Aug 2, 2008 | 01:36 PM
johndoehizzle's Avatar
Member
theres a guy ,thats got the same engine as i do,the d16z6 (92-95),and put a 96-2000 d16 head on it,says the vtec heads were made with a better material in those years...n his ride pulls real nice for a single cam
Black94
17
Aug 5, 2010 08:25 PM
scottdh20
Apr 30, 2008 12:29 PM
scottdh20
Apr 16, 2008 10:45 AM
BoomBox
ED-EF Swaps
Jun 23, 2005 08:48 AM
BoomBox
Jun 6, 2005 03:45 PM
