engine mods while engine is removed?
Old Apr 19, 2007 | 10:18 PM
blaze 92 95's Avatar
Default engine mods while engine is removed?
Im fixing up mny new honda and gettin it ready for the road theres some body work todo and suspension. One thing i gotta do is chage the clutch and i hear u must remove the engine and gear box to do so. while im doin this i plan on cleanin up the whole engine bay. Is there any modifications i should do on the engine while its out somthing that can only be done while its out or its easier that way. The engine is a d15b vtec and i was plain on gettin it port polished but any outher ideas would help. thanx
Old Apr 19, 2007 | 11:10 PM
danomatic93's Avatar
June 2010 ROTM
Default RE: engine mods while engine is removed?
you don't have to pull the engine out! You have to lift it to take pressure off of the tranny mount, then remove the tranny and etc. Who told you you need to remove the engine!?!?
Old Apr 19, 2007 | 11:14 PM
Kedawei's Avatar
Porting the head would be a waste.
Old Apr 20, 2007 | 12:30 AM
Pete's Avatar
You dont need to remove the engine to do the clutch. If youve got an engine out of the bay an intake manifold will take 75% less time to install thou.
Old Apr 20, 2007 | 12:32 AM
drbyers's Avatar
adjust the valves and change the timing belt. once is free, the other is about $50...
Old Apr 20, 2007 | 11:31 PM
Ok so what exactly do i have to do to get the clutch out? and is there any walks through for that and the intake manifold timing belt and valves?
civic08driver
Sep 22, 2011 06:24 AM
fazerman
Jul 20, 2010 07:45 PM
andeeuk
Jan 19, 2006 01:34 AM
b3651
Sep 24, 2005 09:46 PM
olie1984
Dec 5, 2004 01:16 PM
