engine oil?
Old Jun 17, 2008 | 06:06 PM
civic1998ex's Avatar
Default engine oil?
Ok my engine bin making weird noises lately and lacks alot of power so i disided to do valve adjustment when i took of the valve cover and fliped the valve cover over it had like oil on it but it more looks like greese some white ****, so then i cleaned it and put the cover back on and drove for about 200 miles then cheked again it had that **** again built up on the valve cover inside, whata heck is that **** and what could be making it? anybody has any ideas?
Old Jun 17, 2008 | 06:41 PM
CrazyBelk5150's Avatar
Default RE: engine oil?
That means you have water or moisture in your oil system. Check all of your vacume hoses and try an oil change, but dont do an engine flush. If you have a cold air intake you maybe getting it there. If the film continues you may want to pull the head off and examine it.[8D]
P.S. Check your coolant/antifreeze!!!
Old Jun 17, 2008 | 06:56 PM
ok i do have an cold air intake, and i did the engine flush before i cheked the valve cover, so u think that engine flush could caused it? and i also changed the intake manifold gasket like 3 weeks ago and could something be wrong with that?
Old Jun 17, 2008 | 11:07 PM
Civic|UnLimiteD's Avatar
Mobile 1/Royal Purple FTWWW1!!
oilltd
Jun 10, 2008 04:06 PM
FlipHKD720
Apr 27, 2007 04:35 PM
DotComx
Dec 24, 2005 04:06 PM
