engine wont start
Old May 12, 2009 | 07:27 PM
  #21
2fastcivic94's Avatar
yeah its it a bright spark
Old May 12, 2009 | 07:28 PM
  #22
How did you set the crank to TDC1 without the pulley mark?
Old May 12, 2009 | 07:30 PM
  #23
i went by the insert pin thats wat i was told to do
Old May 12, 2009 | 07:31 PM
  #24
Not sure what this is. Please clarify.
Old May 12, 2009 | 07:33 PM
  #25
Did you pull the CEL code(s)?
Old May 12, 2009 | 07:37 PM
  #26
you don't need marks on the pulley to set the crank/cam timing. Just align the mark on the oil pump to the mark on the oil pump gear.
Old May 12, 2009 | 07:38 PM
  #27
Without the crank pulley mark, you need to remove the crank pulley, turn the crank counterclockwise until the cam is at TDC1 and then check whether the crank is also at TDC1 (pointer on oil pump aligns with the mark on the crank gear=TDC1).
Old May 12, 2009 | 07:39 PM
  #28
the key on the crank pulley
Old May 12, 2009 | 07:41 PM
  #29
yeah thats what i did alighed the key enter of the engeine
  #30
Your mechanical timing is off. You need to set the TDC1 timing of the crank gear as shown in the diagram above. You need to align the pointer with the groove in the crank gear not with the key. Close is just not good enough for the mechanical timing.
