engine wont start
I think you need to recheck the mechanical timing.
Also, did you happen to replug the fuel injector connectors in the correct order?
Did you mix up the MAP, TPS, or IACV connectors?
What CEL codes did you pull?
ok pulled code off saying its the spool valve, plus someother ones that i no already about thats non related to why it wont start.
and also its pulling my fuel injectors. now is there a fuse for the injectors?
2) Crank the engine for 30 seconds or more and then pull codes again if the CEL remains ON. Post all CEL codes that appear after cranking.
It's in the service manual that you have. Look at diagram 14 in the very last chapter.
