EX tranny swap
its not a hp gain but im sure it will help because the gears are a little different...if im not mistakin the gears on the ex are shorter then the dx...if they both are hydro trannys and both manual or auto it shouldnt be that hard.
No, there are a few more steps involved than just unbolting it. On the passenger's side, you have to disconnect the lower control arm on the suspension so you can swing the strut out and pull the axle out of the tranny. Up top, I believe there is one mount that is native to the tranny. There are also a few plugs, the clutch slave cylinder, starter, and some other various BS you need to take off. If it isn't already gone, all the stuff you need to remove can be found easily by removing the air box/intake assembly. As for the "unbolting it" part, 4 bellhousing bolts and you're done. (Keep in mind, those are just rough guidelines. I'm postiive there are some other minor parts you need to remove.)
davster
Sep 28, 2007 10:23 AM
badboy4life
Sep 1, 2007 08:28 AM
pregohatch
Jul 9, 2006 09:21 AM
darknightmr2
Mar 14, 2006 06:44 PM
