Grounding Wires
they are all not needed and just ugly....
stick with black wire unless you like that rice wire loom/color looks that is.....
you only need 3 ground wires at max, battery to unibody, side passenger rail to transmision, then front radiator support to the valve cover.... basicaly just replace the factory ground wires with larger gauge wires. thats all ya really need.
keep it clean... please [sm=icon_stickpoke.gif]
Oh sorry, i meant the design (yeah the colors are bad). One of them is just wires, the other is a bunch of wires that branch off from a disc that bolts to your firewall (this one seems like there would be wires everywhere).
Is that just what the first kit does.
ORIGINAL: addiction2bass
...basicaly just replace the factory ground wires with larger gauge wires. thats all ya really need.
the disc one actualy bolts to your batterys ground terminal.... and the other uses your factory ground wire clamp.
pull the cover off your batterys ground terminal and im preatty sure there will be a bolt that the new wires will go on. tho im not positive.... i know the positive terminal does, but i cut off my factory wires along time ago...
