GSR timing belt routing
can anyone do a layout for the timing belt on a GSR motor.
i want to be sure and i also have an issue with it not being tight enough its an obvious that its too loose and i cat get it tighter at all
i lack in the patience department so someone with a diagram and an easy fix would be great
search for the online HELMS manual pdf for your model year integra (engine).
it will have the timing belt diagram in it in great detail.
as for the tension. you can't overtighten it because Honda B series engines have timing belt tensioners and tensioner springs that take the guess work out of tensioning the belt.
if you download the HELMS manual PDF (for free, I might add) it'll show you the proper sequence to put the belt on properly.
Here you go
[IMG]local://upfiles/4155/462710F46D8D46EAB77F0FEABD2119AC.jpg[/IMG]
[IMG]local://upfiles/4155/EB8F65240458489B95A7D6FA97F25EBF.jpg[/IMG]
[IMG]local://upfiles/4155/2A8C157B011B442D9B5F1A2C9C0A4688.jpg[/IMG]
[IMG]local://upfiles/4155/2CEB6A8282DC403B872D6AFC600452E7.jpg[/IMG]
ORIGINAL: MY99SI
the cam gears arent goin to stay put
4th pic, left hand page, big circle.
with cylinder 1 at TDC there are holes in the cams that line up with the cam covers. stick a screwdriver or a punch in there (one in each cam) and that will keep them in place
its fixed now its on and hopefully it'll start tomorrow. i have to put on a few new injector clips then hopefully it'll start tomorrow
ive been fighting with this car for13 months thats the last time i drove it
Kyle700
Sep 18, 2014 07:44 PM
pippo
Jan 26, 2010 02:40 PM
trihonda
Apr 10, 2005 11:48 AM
trihonda
Apr 7, 2005 08:31 AM
