which head?
Old Apr 18, 2007 | 08:53 AM
RCJr9186's Avatar
Default which head?
i currently have a b18a1 long block but looking to get either a b18c GSR head or b16 type R head on it. which do yall recomend? and how much power can i expect out of this swap?
Old Apr 18, 2007 | 08:54 AM
riceburner700's Avatar
Default RE: which head?
whats your goals?
Old Apr 18, 2007 | 09:44 AM
RCJr9186's Avatar
all motor apx 200whp after tuning... high would be fine if this motor will put me there but 200 would be great.
Old Apr 18, 2007 | 11:58 AM
the_turtle's Avatar
i would go for the type R head...although the gsr will give pretty close results...
Old Apr 18, 2007 | 08:23 PM
b18c5 or b16a or b ftw
Old Apr 18, 2007 | 08:38 PM
skylinecivic's Avatar
Banned
personal bro i would ussed a b16 head cuz it gives u more top ended then gsrbut i have a b20 block with a b16 head with type r cams, and aem gears and i am doing 226hp 2 the wheel, researchs shows that b16 does give u that extra top end then gsr and type r they usally give more horses,,,
yhats by ezperience but everyone has there own experiences and stories...
Old Apr 18, 2007 | 10:11 PM
INJENalltheway's Avatar
^You on crack?
Old Apr 18, 2007 | 10:18 PM
drbyers's Avatar
go for the b16 type R head. it's almost identical to the b18c5 Type R head.
the b18c5 Type R head has some extra head work and detailing at the factory but for your purposes the b16 head should be more than adequate.
Old Apr 18, 2007 | 10:27 PM
drbyers's Avatar
btw, you can expect about a 40 hp gain when you mate either head onto a standard b18 LS engine block, but that's not guaranteed.
engine wear, compression and other factors come into play.
Old Apr 18, 2007 | 11:14 PM
Kedawei's Avatar
The B16B, Type-R B18, and all B16 heads are made from the same cast. This means they all flow the same, and power will be the same between them assuming they have the same cams/valve train. The only differences with these heads arethat the Type-R heads have stronger valve train and more agressive cams.
This style head is superior to all other B-series heads in terms of air flow, in stock form. All other B-series heads require porting to match it.
disaznjason
Apr 6, 2011 06:19 PM
Evoman
May 18, 2009 07:02 AM
branx
Mar 24, 2008 04:32 PM
nate081304
Jan 16, 2007 07:41 PM
XCM828
Sep 18, 2005 11:22 PM
