high end or low end
Depends on how you drive, really. If you drive it around above about 3,500 most of the time (like I do) then high end is for you. But if you usually keep your rpms pretty tame, the low end is where you're going to want more oomph.
Actually, the midrange engine speeds (~2,500 - 4,000) are the best places to drive any small displacement I4. If you start digging down too far below that, you're actually putting more wear on the engine than you think, and the reduced oil pressure can cause even more wear issues. Basically, keep it out of the mud and your engine longetivity will increase dramatically.
Well, driving 4,002 isn't going to make a difference. And I consider that conservative even, but my Civ differs a lot from his, so basically, what ever you're comfortable with, just try to keep it up.
rad151
Apr 22, 2009 02:18 PM
Honda_Lover
Jan 10, 2008 05:57 PM
liliechen
Dec 25, 2005 11:15 AM
nachoman
May 23, 2005 02:37 PM
