I got some [ok a lot of] swap questions
Old Aug 21, 2006 | 08:57 PM
Mr Mobsta Man's Avatar
Default RE: I got some [ok a lot of] swap questions
well i found this JDM h22a OBD 1 [I dono what OBD is] Click Would this be a good swap, or an engine like this one? Later on maybe even turbo it at low psi also? Plus i found that i might get about 300 for the engine I have now, better than nothing I guess.
Old Aug 21, 2006 | 09:00 PM
paraplegic's Avatar
ORIGINAL: E2EK1EL
The K20 Has much more torque then the h22, i think h22a=163tq and the k20 is over 200 tq
hahahahaha. dont mean to laugh but the k20 has just about 20 lb ft torque less than the h22 but horsepower is just about the same
h22=163tq > k20=141tq
like one of the guys before me the h22 will run circles around the k20
the h22 is also not a good boosting engine thanks to the aluminum sleeves that is carries
ef4life's Avatar
d16y8 yes it is vtec, and a good starting point if you want a turbo car. and an h22 is a good swap good torque and hp, and availible factory lsd. just an expensive swap, because of mounts and axles and you need to get a shifter from an accord or prelude and run the cables through a hole (you drill) in the firewall or tunnel.
Old Aug 21, 2006 | 09:10 PM
how about this then, i have 151k miles on my car like i said earlyer, any way i would get to 200hp with it without losing the reliablity of a DD? And the reason I would rather do a swap because my engine would last to about 200k or a little more then i would have to get another one anyway so why not just do it now and get a better engine.
Old Aug 21, 2006 | 09:12 PM
ef4life's Avatar
for the price a a swap you could rebuild your engine and get a turbo kit. and make over 200 whp easy. that is if you shop smart
Old Aug 21, 2006 | 09:19 PM
like new pistons and cams, i dono what else, and still pay for labor for some1 to do it cas i cant do any of it myself? and while i was looking at the engine code i was looking at the front of my car, it doesnt look like enough room to fit an intercooler there.
Old Aug 21, 2006 | 09:23 PM
ef4life's Avatar
well i was assuming you would be doing it, but i guess it would be alot of money either way. probably just go with a swap then
Old Aug 21, 2006 | 09:30 PM
No way I could do it myself, I'm 16 and all I have done with the engine was take the valve cover off to paint it.
Old Aug 21, 2006 | 09:49 PM
ef4life's Avatar
why couldn't you do it your self? i am 20 and did my first swap when i was 18, its not that hard to do, its just labor t remove and replace. i had a little help from my friend to do the wiring.
Old Aug 21, 2006 | 09:59 PM
Well I know very little about engines and even if I did know what I'm doing, All I have is a rachet set, wrenches, and some screwdrivers so I don't have the tools for it either I don't think.
