i need to swap
i have a 1991 hb civic d15 i want more power but for a good prices what are the best engines i should look in to and how much were would i find one. the reason i need a swap is bc i want Turbo and the d15 is not my turbo choice
if you want something simple and easy then get a d-series motor with a v-tec head on it. its a bolt on motor no motor mounts needed and also your tranny lines up with the motor. the problem is wiring and getting a v-tec controller also converting obd0 to obd1 or 2 depends on the motor.
price=700 thats motor wiring ecu and other mods
now you can go with a b16 which is v-tec and also dohc and they have a package that includes everything for the swap mounts ecu tranny axles etc. but it cost about 2000 but its worth it trust me.
Yea i've been looking want to go with the b16a 16v dohc vtech pgm-fi 160hp 111 tq cmae with the civic sir right that one or the b18c1 1.8l dohc vtech pgm fi 170 hp 128 tq 94 01 integra would be a bitch do u have ANY WERE I COULD CHECK MORE INFO AND FIND PRICES AND ECT THANKS
Just to clarify a few things, there aren't any VTEC D-series motors that'll bolt right into a 4G Civic. You'd still need a mount kit and a new tranny. For the money (I assume you're looking for cheap) you should look at a blacktop DOHC ZC (probably $600). It IS a direct swap (same tranny, same clutch, same axles, etc...) but you need to make sure your car is wired for MPFI and get an 88-89 'Teg 5 speed ECU. The stock rods should be good for 210 whp, and it's easily buildable.
EDIT: Sorry about that. A SOHC VTEC ZC will bolt right in, but the DOHC is better.
ORIGINAL: hondabboy
