If the timing belt snaps on a Civic 2001 SI?
Old Dec 9, 2008 | 04:32 PM
civique's Avatar
Default If the timing belt snaps on a Civic 2001 SI?
......then what will happen? Will the valves be bent or not? I know that on some motors nothing happens (example my old 95 mazda mx-6), but on my civic SI 2001??
Old Dec 9, 2008 | 05:11 PM
justinwebb's Avatar
February 2010 ROTM
yes you will have bent vavles as its an interference engine....best to change it then to have to deal with it
Old Dec 9, 2008 | 05:29 PM
inthezoneac's Avatar
or you could drive it for as long as possible and once it snaps, that's the perfect time to get a built engine and turbo
Old Dec 9, 2008 | 05:50 PM
you don't have a timing belt, you have a timing chain
it probably won't snap
Old Dec 9, 2008 | 05:57 PM
315 Customs's Avatar
yea they switched to a timing chain in 01 so you are probably good for some time, however it is still an interference motor so if it does break it pistons will smack some valves like a dirty ***** who stole your money
Old Dec 9, 2008 | 06:10 PM
I thought it was only because the 01 Si has a K-series
Don't the D's still have a belt?
Old Dec 9, 2008 | 06:35 PM
yea I meant to put 01 Si's
Old Dec 9, 2008 | 06:57 PM
Masonn's Avatar
It depends if your SI has a K or a D engine. (K series came in US and JDM Si's, but CAD Si's came with D's and were unavailable with the K's. unless it's a SIR)
Old Dec 9, 2008 | 07:41 PM
...so if it does break it pistons will smack some valves like a dirty ***** who stole your money
Wow Kevin. This leaves a vivid impression on you. Has this happened to you?
smackpower
Jan 13, 2024 01:42 AM
Kyle700
Sep 18, 2014 07:44 PM
pippo
Jan 26, 2010 02:40 PM
sd713
Dec 31, 2008 08:30 AM
badlandsusa
May 26, 2008 11:16 AM
