Link to a B Series Swap Write Up?
Old Nov 1, 2006 | 01:16 PM
FlipHKD720's Avatar
Default Link to a B Series Swap Write Up?
Can anyone give me a link to a write up of a d series to B series engine swap? I really wanna learn about this and if its somethin i should consider. Thanks all.
Old Nov 1, 2006 | 01:53 PM
mxs's Avatar
mxs
Default RE: Link to a B Series Swap Write Up?
this is more of just a parts list, but is this what you are looking for?
http://www.phear7imports.net/trey/6gen/
Old Nov 1, 2006 | 02:04 PM
SpanishFly21's Avatar
Man the only thing i can find is K20 swap into and Ek.
Old Nov 1, 2006 | 04:12 PM
ProjectGSR's Avatar
this may not be at all what your asking for, but there is a full b swap guide on a cd on ebay 5 bucks. sorry thats the best i can do
Old Nov 1, 2006 | 04:45 PM
Marty's Avatar
if you have a ex and buy a engine from the same era as yours(obd1/obd2) then it is all bol in. Use Integra axles and the ecu that comes with the swap.
Old Nov 1, 2006 | 09:38 PM
FlipHKD720's Avatar
I have a DX with an OBD2 ECU. Which year/model Teggy, and would i need a ECU conversion harness?
Old Nov 1, 2006 | 09:56 PM
Marty's Avatar
get a 96-00 B16/B18C, get the ecu that runs that engine(P30 or P72), do everything you would for a mini-me, buy 99/00 axles and that is about it. You can buy 99/00 civic si mounts and have everything. I'd go with a H22 though
Old Nov 1, 2006 | 10:12 PM
FlipHKD720's Avatar
ORIGINAL: Marty
You mean you wouldn't swap the whole engine, you'd only swap the head? (and water pump, timing belt, etc.)
And do you mean 99/00 integra axles or Civic axles?
Old Nov 1, 2006 | 10:20 PM
mxs's Avatar
mxs
no, if you swap the whole engine you still need to modify your wiring harness for VTEC
94+ integra axles (or 99-00 Si axles)
also, b-series shift linkage
Old Nov 1, 2006 | 10:46 PM
FlipHKD720's Avatar
ORIGINAL: mxs
You mean soldering/splicing and whatnot, or just getting a conversion harness? Because wouldnt the B series ECU already come VTEC-equipped, which means you should be able to get a conversion harness for it?
FlipHKD720
Mar 8, 2007 06:39 AM
rev2red
Jun 11, 2006 05:54 AM
b8teen
Apr 16, 2006 11:05 PM
jonyg98civicex
Apr 12, 2006 06:46 PM
S240161
Nov 3, 2005 08:35 PM
