my rod blew a hole in the block
Old Dec 6, 2006 | 03:15 PM
ctechaa's Avatar
Default RE: my rod blew a hole in the block
.... that happened to me twice... i was redlining and was running super low on oil.. (idk if the oil had anythin to do with it) but i cracked both my d16 blocks due to hydrolock.
Old Dec 6, 2006 | 10:29 PM
riceburner700's Avatar
you cant compress liquid, if you did more than likely you would bent the connecting rod into a pretzel
Old Dec 6, 2006 | 10:42 PM
Misha's Avatar
It's almost always a mistery what exactly caused the rod to blow. But it is not revving per se. Your rev limiter triggers at the safe speed with a significant safety cusion, so you don't need to worry about it. However, if you boosted your engine, you ever run it low or no oil, you hydrolocked, etc., etc., it all adds up and finally snaps....
Old Dec 6, 2006 | 10:57 PM
Pete's Avatar
I wanna see the "hole" I completly toasted my engine, and there was a crack in the block, but no hole....and I was at 10 PSI on my D.
Old Dec 6, 2006 | 11:01 PM
Misha's Avatar
I saw one on my turbodiesel Galant. It was not big, but was definitely a hole... It probably depends on how rod broke.
Old Dec 6, 2006 | 11:36 PM
Pete's Avatar
Yea, but he said he saw a "Huge" hole lol.
Old Dec 7, 2006 | 07:37 PM
Kedawei's Avatar
Holes can be made. It just depends on where the rod flies and how large a chunk was left of it.
Peg_Leg
Aug 8, 2010 09:27 PM
RP Sinisterx
EK Swaps
18
Aug 6, 2009 08:50 AM
zsatbecker
Apr 19, 2009 02:00 PM
redblur07
EK Swaps
May 1, 2008 02:28 PM
POLYTHING
Apr 17, 2007 11:01 AM
