need help..Civic tune up list
Old Oct 14, 2004 | 10:10 AM
lilthanh19's Avatar
Default need help..Civic tune up list
Hey guys...first post here...i have a 2000 Civic DX....what does the tune-up list consist of for my car if i want to do it myself?
Old Oct 14, 2004 | 04:48 PM
NTX's Avatar
NTX
Default RE: need help..Civic tune up list
if you want to do a major tune-up:
Spark plugs: gap and replace also check the wires for cracks
Oil and filter: drain and replace
Air filter: check and replace if necessary
Coolant: check and replace if necessary
Valve adjustment
PCV valve: check and replace if necessary
Timing belt: check for wear and change if necessary
Water pump: check for leaks
Accessory belts: looks for cracks and replace if necessary
Transmission fluid: check flevel and color (replace if necessary)
Power steering fluid: check and top off
Brake fluid: check level and color (replace if necessary)
Front & Rear brakes: replace if most of the thickness has been worn away also check the lines
Parking brake: check and adjust
Tire rotation: Check pressure and tread and rotate
Hoses: check for spongy hoses or cracking (replace if necessary)
Fuel lines & filter: Check and replace if necessary
suspension & steering: Check for loose components, check cv joint boots for leaks
I'm sure i'm missing something, but that should do it....
oh....also check and adjust the timing....
Scott53092
29
Feb 27, 2010 04:47 AM
PodRacer93
EG Swaps
Nov 17, 2008 01:09 PM
natecivic92
Mid West
Aug 9, 2007 12:07 PM
slvcivic00
29
Jun 3, 2006 01:53 AM
97civicrally
Jul 11, 2004 02:22 PM
