NOOOOBBbbb HELP!!!
Old Apr 27, 2011 | 03:42 PM
turbospec.91's Avatar
Default NOOOOBBbbb HELP!!!
Ok so today i did a tranny swap on my 97 ex hooked everything up.... started it up and pulled out of the garage after driving it for a min or so it acted like it popped out of gear.... I can put the car in gear and give it gas and my speedo goes up but im not getting any power to the wheels... What is the problem??
Old Apr 27, 2011 | 07:21 PM
Not one reply to my post.... thanks guys peace
Old Apr 28, 2011 | 02:33 PM
got2run5's Avatar
I'd help you if I knew ANYTHING at all. But... try going to civicforums.com and posting in the right generation section. I've realized they tend to have more ppl than this site.
Old Apr 28, 2011 | 05:44 PM
This site is not as active as others. We will post up if we know an answer for sure. Also, the General Maintenance section is more active IMO, too. You can try other forums such as honda-tech if you would like, too.
Look under the car. Axles still in the trans/hub? that's all I can think of.
Old Apr 28, 2011 | 06:37 PM
Scott53092's Avatar
^ Sounds plausible, axle end may hop out of the transmission. It is an actual problem that does happen, when it comes out of the diff the car won't or will barely move. So take a peek and make sure you seated the axles in the trans correctly the first time. You should feel them pop in, you will know when the axle is in as you can feel it lock in the diff.
Old Apr 29, 2011 | 02:55 PM
Figured it out it was the little cv clip on the end of the axle was broken i popped another one on then put it back together and it drives fine now thanks
stevenc
Jun 25, 2008 09:57 AM
redridinhood
Oct 9, 2006 07:27 PM
superballa22
Sep 18, 2006 05:06 PM
coolguy1234
May 7, 2006 08:31 PM
Jas10hon
Jul 4, 2005 10:35 PM
