not sure what direction to go
Old Nov 8, 2005 | 02:00 PM
rizzle's Avatar
Default not sure what direction to go
I have a 04 civic ex coupe. my engin is a stock d17a not sure what to do i have installed aem v2 intake and cat back exhaust. not sure weather to swap or build on existing engine any suggestions?
Old Nov 8, 2005 | 02:48 PM
ngoti 8tor's Avatar
Default RE: not sure what direction to go
I believe a swap for the 7th generations would be very expensive. You're probably better off to build your existing D17A.
Old Nov 8, 2005 | 03:58 PM
Chimera02EX's Avatar
DC 4-2-1 headers, fuel system, suspension, engine internals, EMS, larger injectors, turbo?
Old Nov 8, 2005 | 04:00 PM
Nail I3unny's Avatar
building a D17?
have fun
but seriously...in the long run it'll be cheaper to swap the engine. its damn near impossible to find aftermarket parts for the D17 other than turbo parts.
Old Nov 8, 2005 | 07:13 PM
Thats not true Nail. The only part I have not found for my D17, is an intake manifold.
Old Nov 8, 2005 | 08:25 PM
es2001civic's Avatar
I have same gen and it is a bit of a pain. The parts are a bit of a pain to find and are limited which makes em a bit expensive. I started off wanting to do all the bolt on's and then turbo with internals . Came close to droping 2k a week ago .But after all the research ive done my opinion is to save up and do an engine swap. Its the best way to get real power.
Edit: It realy comes down to what you are trying to achieve with your car and how much time and money you are willing to spend.
Old Nov 8, 2005 | 08:56 PM
I still don't understand what all of you are talking about, the D17 has plenty of potential. Granted it's not like a K20 or B18 but for a 7g the only swap you can do is a K20, so you're gonna drop like 6k on a swap when you could have upgraded the internals and got a turbo, and got it tuned???
Ok granted you prolly won't get 400hp outta a D17, but 250hp wheel hp is attainable, and that's nothing to squak at.
HelpMyHonda
May 22, 2006 08:52 PM
mike1987
Dec 9, 2005 09:37 AM
chriskatana
Aug 10, 2005 10:15 AM
bradwitt
Jul 1, 2005 04:23 AM
hisokano1
Apr 3, 2005 08:30 PM
