Problems with the Ex
Old Mar 27, 2006 | 12:31 PM
seriously_furious's Avatar
Default Problems with the Ex
Whats up guys. I am sure this is a quite common problem with slightly older honda's but i couldnt find it here. So... does anyone have an idea why my steering wheel shakes on my 97 honda civic ex 2 dr coupe after i exceed the speed of 60 mph
Old Mar 27, 2006 | 12:37 PM
mxs's Avatar
mxs
Default RE: Problems with the Ex
bad tires, or wheels out of balance most likely.
Old Mar 27, 2006 | 12:38 PM
well brand new tires and rims. You think i prolly just need a tire rotation or a camber kit would probably be the best solution
Old Mar 27, 2006 | 12:39 PM
jelled21's Avatar
Try getting the tires balanced. If that isn't it, then I would take it to a reputable shop and get the alignment checked. Don't just go to Big O or Discount Tire, or any place like that. They use the three bar alignment, which only does toe adjustments accurately, not camber or caster. It is probably just wheel balance though, remember, under 60 it is usually tread separation, over 60 wheel balance. Let me know how it goes.
Old Mar 27, 2006 | 02:09 PM
Chimera02EX's Avatar
Balanced!!!! Your tires are outta balance. Get them done and you will be right as rain.
Old Mar 27, 2006 | 02:32 PM
RaskyR1's Avatar
ORIGINAL: seriously_furious
If their brand new they shouldn't need to be rotated...So i'm guessing you car is lowered? There is a lot of possible reasons....most are listed above...you could also have a bent rim from a pot hole, bad tire wear (since it sounds like you lowed the car) maybe a ply seperation in the sidewall...how many miles do you think you have on the wheels and tires?
jrobles26
Jan 1, 2006 11:05 PM
green98lxsedan
Aug 9, 2004 02:30 AM
lil frog
Jul 8, 2004 08:07 PM
Tenchi_Wannabe
Jul 6, 2004 02:15 AM
tgamer
Jun 27, 2004 06:29 AM
