Rebuilding...
Old Feb 13, 2007 | 07:11 PM
johnb's Avatar
Default RE: Rebuilding...
ORIGINAL: cderalow
i think this is the 2nd or 3rd time this guy has asked a bunch of noobish questions about stuff... like where to find k20 etc...
you dont need to be a big ******* about it. im on here to learnabout how to do things thats the purpose of this forum. if im irritatingyou then go to a different section and dont reply to my posts.
Old Feb 13, 2007 | 10:50 PM
Kedawei's Avatar
ORIGINAL: johnb
P.S. I DO NOT WANT TO BUY AN OLD CAR TO PART FROM.... just want to make what i have sick as ****....
I always get a kick out of this line. That motor sucks, and the car's heavy, but you probably know it. Best shot you have to do anything with that motor: Crower rods, CP/Wiseco pistons, full headwork, full custom turbo kit, AEM standalone + tune, then the drivetrain. All said and done probably cost youabout 6-7 grand in parts alone, then labor for everything, and it still may not even last you very long if you don't know what you're getting into.
Old Feb 13, 2007 | 10:52 PM
FlipHKD720's Avatar
ORIGINAL: cderalow
ORIGINAL: FlipHKD720
ORIGINAL: drbyers
if that's the case then hotter cams, beefier pistons/rods and block sleeving are needed (which will help if you ever turbo).
.....wish somebody would explain sleeving to me[&:]
sleeving is the concept of boring out and machining the area around the cylinders to a wide diameter, and then placing precisely machines tubes of stronger metal in these slots...
the idea being replacing the not so strong stock engine block material with a stronger more durable layer right around the piston.
you can also increase displacement at the same time
oooh, i thought that was called boring an engine out.
Old Feb 14, 2007 | 12:13 AM
Kedawei's Avatar
^ You can only bore so far before you have to sleeve.
Old Feb 14, 2007 | 03:07 PM
johnb's Avatar
ORIGINAL: Kedawei
ORIGINAL: johnb
if i do all that is it going to make my red line later? like 8 or 9? and would you recommend doing this or buying a k20?? thank you for all of your help.
Old Feb 14, 2007 | 03:39 PM
Kedawei's Avatar
I would not be comfortable reving (or modding) a D17 that high. K20 would be a way better way to go.
Old Feb 14, 2007 | 06:34 PM
mxs's Avatar
mxs
k-series are much better engines than D17
Old Feb 14, 2007 | 10:09 PM
Nail I3unny's Avatar
i would not feel comfortable building a d17 for boost unless you sleeve and bore...or shorten up the stroke. its not exactly a good bore/stroke ratio for boost.
Old Feb 14, 2007 | 10:38 PM
Remmy's Avatar
OR
ORIGINAL: Nail I3unny
Its not a good motor to screw with heavily to begin with.
Old Feb 17, 2007 | 11:33 AM
johnb's Avatar
alright...that sucks lol thanks for ur guys' help though..
