Swap
Old Nov 6, 2007 | 02:19 PM
flatfoot224's Avatar
Default Swap
i have a 97 civic ex, could i swap the b16 engine into it with out changing the transmission, and would it fit without alot of extra parts?
Old Nov 6, 2007 | 02:23 PM
classiccarsrule85's Avatar
Default RE: Swap
Well a B16 would bolt right into your car....that is if you got the si engine.....but you will need to swap the transmitions D dose not work with B....but correct me if im wrong you will need different axels and ecu as well. Might as well jsut get a B18b1 or C1
Old Nov 6, 2007 | 02:30 PM
Default RE: Swap
i figured i would need the new ecu and stuff, does the b18 produce more power? is that the type r engine?
Old Nov 6, 2007 | 02:53 PM
Lost's Avatar
Default RE: Swap
B18B = LS/RS/GS
B18C1 = GSR
B18C5 = Integra Type-R
For the b16 youll need new mounts, tranny, shift linkage, ecu, harness, axles.
Old Nov 6, 2007 | 03:04 PM
Default RE: Swap
is the tranny on manual or auto also?
taintedsaint
EG Swaps
May 16, 2008 04:46 AM
EKswapInfo
EK Swaps
Sep 26, 2006 05:33 PM
WhiteCivic15
Jul 7, 2006 03:17 PM
00civicEX_3
EK Swaps
Feb 26, 2006 11:08 PM
nemesis08
Jun 8, 2005 08:05 PM
