Timing question
Old Jan 26, 2007 | 07:33 PM
mig25's Avatar
Default Timing question
For some reason my civic 95 DX auto knocks valves on third gear,
When I am picking up speed I hear the valves pinging.
I have set the timing , Shorted the connector on the passenger side, the marks are perfect.
The only thing weird is that the distributor is turned to the maximum settings foward. . I am not sure why my valves are ticking.
I did adjust the valves to correct specs.
Any Hints ?
thanks
Old Jan 27, 2007 | 10:12 AM
riceburner700's Avatar
Default RE: Timing question
set your timing were its sappost to be at. How do you know its the valves ticking maybe its detontion? have you done like a timing belt latly or anywork done to the motor that would make a ticking noise if not done correctly?
Old Jan 27, 2007 | 01:17 PM
civicblend97's Avatar
could just be the gas u got making it spark knock... riceburners question about the work done latley to...could need a tune up...
smackpower
Jan 13, 2024 01:42 AM
Legend1011
Apr 22, 2006 03:09 PM
molson
Mar 4, 2006 07:14 PM
civicexracer
Feb 4, 2006 10:19 PM
Elnyne
Aug 24, 2005 05:17 PM
