Timing Question
yes, you can time it with a timing light. on the crank pulley there should be 5 marks. the mark in the middle of the group of three is the setting you want to set it to. line that mark up with the v in the belt cover and another tab in the timing cover
I really hope you're not talking about not knowing where the TB marks are, because if you put it on a tooth or two off, then try to run the car, the only thing you're going to get is bent valves.
ORIGINAL: Kappa22
Legend1011
Apr 22, 2006 03:09 PM
