valve cover gasket?
Old Aug 20, 2007 | 05:19 AM
Default RE: valve cover gasket?
Aren't the bolt washers on top of the cover, so they slide off the bolts as part of taking the cover off? That's how the non-VTEC ones are anyway.
It's fine to try to reuse everything, worst that can happen is you have a slight oil leak until you get a new gasket. Make sure the gasket stays with the cover as you remove it. Sealer should not be necessary unless the gasket gets seperated from the cover. Even then use only a small amount at the corners where it goes up to the round parts for the camshaft.
Old Aug 20, 2007 | 05:31 AM
2slo4u's Avatar
Well I have changed the gasket and the sparkplug groments. I want to go ahead and replace the bolt washers before I reassemble every thing.
The rubber washers are hard and cracked. The bolt has a flange on the end of it keeping the rubber washer on. Its hard as hell to get those washers off the bolts.
Old Aug 20, 2007 | 08:53 AM
2slo4u's Avatar
Bump^^^^
Any one else ever replace these rubber washers?
Old Aug 20, 2007 | 03:59 PM
2slo4u's Avatar
ORIGINAL: 2slo4u
Bump^^^^
Old Aug 21, 2007 | 03:55 AM
no, stop bumping the thread 3 times a day, someone will answer soon
Speed JUnkyz
Mar 15, 2010 03:34 PM
PREKGSR
Sep 30, 2007 08:37 AM
jimijam
Aug 12, 2006 09:32 PM
mill$civic
Oct 31, 2005 06:25 PM
SoCaL.rider
Jul 16, 2005 03:36 PM
