VTEC NOT WORKING
Old Sep 21, 2007 | 04:01 AM
mayder's Avatar
Default VTEC NOT WORKING
Basically ive just had a b18c4 (it does exist)bottom end and b16a top end engine conversion and the vtec dosn't kick in.
The speedo isn't working which seems to be the sensor and not any thing else ( i went through a ford and my engine hyrolocked thus new engine)
Am i right to assume that because the ecu isn't technically getting a speed reading it thinks its stationary and the vtec won't engage, just like sitting there reving the engine wont engage the vtec.
I've read this before and just wanted to check.
I beleive the vtec is wired up ok aswell.
Old Sep 21, 2007 | 04:25 AM
Default RE: VTEC NOT WORKING
VSS - Vehicle Speed Sensor
Old Sep 21, 2007 | 08:02 AM
99silverSI's Avatar
It's your number 15 fuse, runs the speedo and your vtec runs off your speedo (weird I know). If you replace the fuse it all shall work, but beware it will blow again. Like Forty04said, VSS - Vehicle Speed Sensor!!
Old Sep 24, 2007 | 07:16 AM
amg6975's Avatar
Wait, VTEC shouldn't run off vehicle speed should it? Wouldn't it be the tach signal?
Old Sep 24, 2007 | 07:25 AM
ORIGINAL: amg6975
If the VSS doesn't work, neither do the speedo or vtec
Old Sep 24, 2007 | 08:21 PM
amg6975's Avatar
Hm, I'll take your word for it.
Old Sep 24, 2007 | 08:27 PM
riceburner700's Avatar
low oil has caused vtec to not work before
gunaa
Oct 22, 2009 11:36 AM
chrisroug
Oct 2, 2006 11:36 AM
BlueEX
Jun 29, 2006 10:02 PM
VTECivic95
Jun 18, 2006 03:11 PM
VTECivic95
Jun 17, 2006 12:37 PM
