What do i need for a jdm d15b vtec swap..
Old Nov 17, 2009 | 10:51 AM
egvtec14's Avatar
Question What do i need for a jdm d15b vtec swap..
I own a eg6 92 no vtec
whould the motor bolt right in?????
Or wut elses do i need?
Old Nov 17, 2009 | 11:20 AM
yes it will bolt right up, but i suggest just getting a d16z6 head and putting it on your block, you will have vtec and more hp, all that is need to hook vtec up to work is you need the vtec head, and a p28 ecu there will be wires for the vtec, one is ground and the other 2 you run to the ecu,
i have some extra pins so you can wire it upto your ecu,
this is where they go, i converted my eg to vtec,
pin a4 is the vtec wire from the vtec solnoid,
pin d6 is the oil pressure switch
and i grounded the black wire coming from the oil pressure switch to the thermostat housing
ef_vtec_sohc
ED-EF Swaps
Apr 26, 2016 07:43 AM
Booger
EK Swaps
Aug 9, 2011 10:11 PM
ef_vtec_sohc
ED-EF Swaps
Jun 3, 2011 10:19 PM
4doorcivic9
May 16, 2007 06:56 PM
randommike88
Apr 28, 2007 09:26 PM
