what do i need for a mini me swap?
Old Jul 17, 2008 | 07:50 PM
bigmikew1's Avatar
Default what do i need for a mini me swap?
someone is parting out there civic and offered me a z6 head and asked me to make an offer and tell him wat i need. not sure wat z6 heads usually go for so not sure of a price to throw out. it will be picked up cuz he is in NY too. i was gonna ask for the intake mani and distributor. wat else should be asking for? and how much?
Old Jul 17, 2008 | 10:05 PM
bcrichguitars's Avatar
Default RE: what do i need for a mini me swap?
Required:
D16Z6 Cylinder Head (Including distributor cap, valve cover, plugs/wires, VTEC solenoid, etc)
D16Z6 or D16Y8 Head Gasket
P28 ECU
D16Z6 Timing Belt
Wire and plug for VTEC oil pressure switch
Optional:
D16Z6 Intake Manifold
D16Z6 Exhaust Manifold
*If you remove your manifolds, make sure you get new gaskets
Recommended:
NEW OEM-
Water Pump (for the block you are using)
Spark Plugs (HX D16Y5)
Spark Plug Wires
Valve Cover Gasket
Distributor cap and rotor
Old Jul 18, 2008 | 01:22 AM
FlipHKD720's Avatar
theres a DIY for it HERE https://www.hondacivicforum.com/m_45390/tm.htm
Old Jul 18, 2008 | 06:08 AM
bigmikew1's Avatar
thanks for the link. was looking for it. didn't know it would be in drivetrain diy.
Old Jul 18, 2008 | 08:12 AM
Mistaashby12's Avatar
I have a 1.7vtec head intake fuel rail and a bunch of other **** for a conversion if interested?
chbulldogs11@msn.com
May 27, 2011 09:05 PM
khanselman
Aug 25, 2006 12:40 PM
civicblend97
Apr 27, 2006 03:38 PM
nemesis08
Jun 8, 2005 08:05 PM
GSXF
Feb 23, 2005 09:45 PM
