1995 civic
Old Jul 29, 2009 | 04:39 AM
  #181
Dipsetcivic117's Avatar
same thing happened to me. mines happend to me when i got to my school for my soccer game. luckly it happened when i got into the parking lot. but then i had to replace it after my game which then was dark out. so i had a fun time replacing it in the dark. and then couple days later...one nlew that goes out of the back of the engine, loops like a u and then goes back into the engine. that one was a pain in the ***.
Old Jul 29, 2009 | 08:42 AM
  #182
FRZ's Avatar
FRZ
upper radiator hose is what you need
Are you sure? That one doesn't seem to have any problem, leaks or anything. The one that's busted and need to replace is one in the back of the engine that goes to the thermostat. The coolant came right out of there to all over the battery, filters, part of the engine and the hood. When I was trying to repfill the coolant to cool the engine and try to make it home, I could see the coolant coming out of that hose as I was putting it in.
Old Jul 29, 2009 | 09:16 AM
  #183
replace the one your talking about you might be able to just cut it and put it back on also i'd replace the thermostat.
Old Jul 29, 2009 | 12:59 PM
  #184
FRZ's Avatar
FRZ
Yeah, I'm gonna replace the thermostat. I think that was my main overheating problem cause all this time it seems like the coolant was circling around the engine to the radiator as it should. But, I don't know If I can reuse that hose, it might be too short after cutting. Idk, I'll see.
One question, how do I check if my intake manifold is working properly and pulling a good amount of air into the engine?
Old Jul 29, 2009 | 01:14 PM
  #185
what do you mean?? if it isnt pulling a good amount of air then car would run like §hit.
do you have a good air filter?
Old Jul 29, 2009 | 01:55 PM
  #186
FRZ's Avatar
FRZ
Nope that is why I am getting a cold air intake being shipped to me today but, I am talking about the manifold itself. How do I know if its pulling the air as it should and its not slow or something?
Old Jul 31, 2009 | 05:20 AM
  #187
FRZ's Avatar
FRZ
Question, what is the difference between a low temp thermostat and high temp thermostat and which one do I have?
Old Jul 31, 2009 | 05:56 AM
  #188
FRZ's Avatar
FRZ
Another question, I found out that the 96 engine that I have was suppose to have a short peace header with a three way catalytic converter that uses two o2 sensors. I don't have that and apparently only one o2 sensor. Does that affect the car's driving much or at all?
Old Jul 31, 2009 | 06:39 AM
  #189
you should have a cel on if it requies 2 o2's and only have 1
difference between low temp and high temp is well self explainitory
one will open up and keep motor low temp
and the other will stay closed longer til it gets a higher temp this one is best used for up north for cold winters since your car's heat runs off the water from the engine
Old Jul 31, 2009 | 09:00 AM
  #190
FRZ's Avatar
FRZ
So low temp would be better IMO so my car stop over heating. And yes, my cel is always on. So if I get another three way catalytic converter I could fix that but, I wonder where the other o2 sensor is? I don't think the 95 civic needed it, so its probably not in the car at all.
