1995 civic
Old Jun 9, 2009 | 07:40 AM
  #161
Dipsetcivic117's Avatar
an easy way to check your cooling fan is to remove either the fan motor or the rear window defogger. first make sure that they work where they are. if the blower works then switch it to the cooling fan. if fan turns on then you know its the relay.
Old Jun 9, 2009 | 08:44 AM
  #162
FRZ's Avatar
FRZ
I have tried that and they don't work. I am getting a new relay today from autozone that I already ordered, so I will find out if the relay is the problem. I was finally able to remove it yesterday under the hood from the socket and saw that there was a jumper wire in it. It must have been bad for a while and the previous owner never changed it.
As a side question, what is the difference with the three relays, coolant fan, heater motor, and defroster? They all 12v and look the same to me in shape and size.
Old Jun 9, 2009 | 09:05 AM
  #163
FRZ -- Do yourself a favor. Buy a multimeter and learn how to use it. Replacing parts at random is just too expensive, frustrating, and time consuming.
Old Jun 9, 2009 | 09:57 AM
  #164
they are the same. no difference
Old Jun 9, 2009 | 12:40 PM
  #165
FRZ's Avatar
FRZ
I was thinking about that when I was at the autozone. I am about to go there in a few minutes so, I think that is what I will do.
Old Jun 9, 2009 | 01:04 PM
  #166
Also check Walmart (automotive section), Sears hardware, and Harbor Freight Tools for digital multimeters. A basic model should cost $15 to $25.
Old Jun 9, 2009 | 04:04 PM
  #167
FRZ's Avatar
FRZ
Got on at autozone, not digital though, actron pocket electrical tester $14.99.
Old Jun 9, 2009 | 04:18 PM
  #168
A non-digital (analog) multimeter has the potential to damage some sensitive electronic circuits. You really should have a digital multimeter for troubleshooting automotive circuits.
Old Jun 10, 2009 | 01:07 PM
  #169
FRZ's Avatar
FRZ
Well, its not the relay. I changed it and the fan still doesn't come on.
Old Jun 16, 2009 | 09:52 AM
  #170
FRZ's Avatar
FRZ
I finally had an auto shop looked it up for me and it turned out it was a fuse under the dash. That was fixed and now the fan and my heater works.
I am thinking how have I known, would of much rather be dealing with the EX model. I may just look for a new shell and forget about this one and swap whatever parts possible.
