Do VTECs leak oil when they hit vtec or just leak in general?
Old Nov 28, 2011 | 07:00 AM
theRDRman's Avatar
so there are no advantages of a lsd ys1?
Old Nov 28, 2011 | 07:21 AM
Except for the fact of LSD, I would assume one YS1 trans is the same as the other.
Old Nov 28, 2011 | 07:24 AM
theRDRman's Avatar
what exactly is a lsd, and my head says its pr3-1 and my ecu says pr3-003 what is that ecu out of and will with rob me of hp?
Old Nov 28, 2011 | 07:53 AM
Google..... Before you ask a question. Google it first. Please.
Old Nov 28, 2011 | 08:25 AM
boiler1's Avatar
My b16's primary leak on that side was the Vtec controller base gasket. If you really think it's only leaking when you hit vtec, then maybe you should consider this one first before doing the cam seal.
The cam cap seal commonly goes on these engines, but if I didn't have to replace it I wouldn't bother.... you should really get a new valve cover gasket, and hondabond as well, so it's not just the cost of the cam cap..
Old Nov 28, 2011 | 11:13 AM
theRDRman's Avatar
yeah good idea man thanks! for some things google is totally useless and even if i see something i run it through you guys cus all of yall know your sh*t
Old Nov 28, 2011 | 11:44 AM
yes there is advatages see post below
LSD stand for Limited Slip differential. non lsd has a open differential which means the wheel that has least amount of traction is going to spin. pretty much like one wheel drive, having lsd when a wheel starts to spin faster then the other then power is applied to the other wheel. there are some great Youtube videos that show and explain all of this. just type how does LSD work.
Pr-3 is the engine code that stand for a b16 engine. now on the ecu pr-3 is again for b16 and the last set of numbers is just production. 1-51 means its for a manual and 52 - 99 means its for a auto.
Old Nov 28, 2011 | 04:18 PM
theRDRman's Avatar
ok so my pr3-003 is a manny ok thx and yeah ill check it out
WILMER007
Dec 24, 2008 11:46 PM
oilltd
Jun 10, 2008 04:06 PM
JIMLARCH
Mar 25, 2008 09:55 PM
Gonzo
Mar 16, 2008 04:47 PM
