driver's power window
Hello I have a 96 civic which the driver window does not work.I searched the threads to find some ideas,but none have worked. The car is a coupe Pass. window works drivers doesn't.Is there a fuse for just the drivers window?? With the door pannel off. Window apears to be set in the track fine (window is in up position)
Switch checked with meter : 12v good - ground good ,when I move the pass window switch I get up and down 12 v readings While checking driver side nothing . Sounds like the switch, power goes and does not come out. Any way I look at the motor and it has 4 wires so not wanting to do more damage I do not apply any power to test.
So I pick up a switch and of course The problem is still there.. Any Ideas?? Thanks
Did your car get wet in past few days? I know sometimes when mine gets wet a few of the connections in the door get all messed up.
If that is not it, then yeah it sounds like it the switch that is bad. Test it by using a jumper wire. Just be careful when you do it.
Ashtim1514
Feb 20, 2015 11:23 AM
gu014
Nov 30, 2007 06:11 AM
jayt720
Sep 22, 2006 04:43 PM
