High temp paint question
RE: High temp paint question
High temp paint only helps the paint not to fade as quickly as regular paint because it's heat resistant. I don't think the paint will prolong the life of the header.
I just purchase some USED Dc Sport header form this sight and are just a little rusted and I'm not using heat paint instead I will Powder Coat them . Powder coating lasts way longer than heat paint
Any kind of coating or insulation will make the pipe run hotter. More air circulation is the only way to make your pipe cooler.
If you're running too lean your pipe will definately overheat.
liliechen
12-25-2005 11:15 AM
