How can i check the size of my gas tank?
Old Feb 17, 2010 | 10:52 PM
1995CivicEXBMF's Avatar
Default How can i check the size of my gas tank?
Im supposed to fill up to at least 12 gallons but for some reason I only can fill up to 7 gallons from an empty tank. I need to know so i can figure out if its a sending prob or if the idiots that had the car before me switched out to a smaller tank. Thanks
Old Feb 17, 2010 | 11:07 PM
Jacototheb's Avatar
It should be 12 gallons. I'm not sure, but your if they didn't swap out your gas tank, it may be your fume vent. I've heard of those causing problems in filling gas tanks up to a certain point. Just a suggestion for something to look into!
Old Feb 18, 2010 | 05:39 AM
norbster86's Avatar
I doubt you have a smaller tank, by looking at that image. Unless they strapped a gas can under your car
Take a look at the pic, then get under your car and look at the tank.
How many miles do you get to a "tank" (according to your fuel gauge)?
Fill up a gas can and put it in your trunk. See how many miles you can go with the needle on E. You could have a bad sending unit.
Old Feb 18, 2010 | 11:42 PM
I would if i had room in my trunk ill put in my back seat haha but ill try that because i get about 250 miles by the time the needle hits the red that was a hunch of mine to about the sending unit
Old Feb 19, 2010 | 12:15 AM
I have the same issue. I think our gas gauges are just inaccurate and we aren't really almost empty when we fill up. I ran out of gas once a while ago and when I filled up I had to pump almost the capacity amount of gas that time, but that was the only time it ever happened.
Just don't run out of gas trying to see how low you can go! Better off just filling up like you always have.
Old Feb 19, 2010 | 11:26 PM
yeah i only pay 25 for 250 miles Ive just been wondering so i can fix it
edwinss4
Dec 6, 2010 06:10 PM
Sprite_15
Nov 6, 2007 04:18 PM
Jayman911
May 26, 2007 06:05 AM
CarmineD187
Jun 12, 2006 10:19 PM
fast93civic
Feb 7, 2005 09:34 PM
