Identifying Your Engine
Old Jan 28, 2009 | 11:25 AM
  #121
bonestockcivic's Avatar
Originally Posted by Darklisk
A guy at my local autocross in a crx was running what he called a Jap spec. R. motor. The redline was 9g any ideas what it's really called and how hard it would be to get one?
if it's the civic type r motor it's a b16. it's probably a b16b series. if it's an integra type r, it's a b18c. b18c is NOT worth the money. it cost too damn much. you can build a b16a2 for REAL cheap. My redline is 8300. it pulls like a freight train and it's EASY to find parts for. and the head is more times than not used as the basis for a frankenstein motor.
Old Mar 18, 2009 | 04:11 PM
  #122
atikovi's Avatar
What about the specs for the engine in my '99 GX? I've heard it has some crazy compression ratio of over 12 to 1?
Old Mar 18, 2009 | 04:49 PM
  #123
The 99 GX has a D16b5. Here are some specs. These are directly from Wikipedia, so apparently no one knows some of the info:
D16B5
(Identical to the D16Y5. Main differences are Pistons, Rods, Camshaft, Head Gasket, Intake Manifold, and Exhaust Manifold are PDN rather than P2M)
  • Found in:
    • 1998-2000 Honda Civic GX
      • Displacement : 1,590 cc (97 cu in)
      • Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
      • Rod Length : 137 mm
      • Compression : 12.5:1
      • Combustion Chamber Volume : 32.8 cc per cylinder
      • Power : ? hp (? kW, ? ps) @ ? rpm
      • Torque : ? ft·lbf (? kg/m, ? Nm) @ ? rpm
      • Valvetrain : SOHC VTEC-E
      • VTEC Switchover : ? rpm
      • Fuel Control : OBD-2 MPFI
      • ECU Code: PDN-A02
Old Mar 29, 2009 | 12:02 PM
  #124
Originally Posted by maiato
Hi all, my civic is a 1994 hatchback, and on the engine it´s a D15B2. I would like opinions on this engines please.
Thanks.
Sorry to inform you...
it's SLOW.
Reliable engine, yet very weak.
Old Mar 29, 2009 | 12:41 PM
  #125
jprommel's Avatar
Angry Admin
it's SLOW.
stu in for the zing
TWO MONTHS LATER!!!!
Old Mar 29, 2009 | 12:44 PM
  #126
Originally Posted by jprommel
stu in for the zing
well he just made his second post so i went to see his first one and I was assuming it was around the same time as his second post.
weird, why would you post once and then not come back and then come back 2 months later and only post one more time?
Old May 6, 2009 | 02:44 PM
  #127
Greko96's Avatar
I have a 2003 Civic EX. Can Someone please tell me what engine I have?
Old May 6, 2009 | 04:54 PM
  #128
D17a2
Old May 15, 2009 | 10:01 AM
  #129
Red_DX's Avatar
I have a '91 DX with a d16 swap. I've found four 96-98 d16 auto's and a '99 f23 with a 5-speed. My questions are:
1. Would the newer d16's mount up to my '91 5-speed?
2. And would the 2.3 even FIT between my fenders?
Thanks! I need to buy a motor ASAP
Old May 15, 2009 | 10:17 AM
  #130
1. yes
2. not sure
