remote lock does not work
Old Jun 24, 2011 | 11:32 AM
s_raghu77's Avatar
Default remote lock does not work
Hi
I have a Honda Civic 2000 LX,
problems:
Remote lock does not work
Manual lock/unlock on driver seat does not lock/unlock the right passenger door.
Any suggestions on how to deal with this? anything like do-it-yourself kinda thing here?
Regards
Raghu
Old Jun 24, 2011 | 03:10 PM
Hous's Avatar
Originally Posted by s_raghu77
Hi
problems:
Regards
Raghu
Check the fuse under the hood, not the one under the steering wheel. Its a yellow one near the condenser fan fuse. Chances are its bad.
About the second problem, are you unlocking with the key or are you using the power lock on the door panel? Only the power lock will unlock the right passenger door, and if the fuse is bad the power locks wont work.
If the fuse is good check the battery in your remote.
Old Jun 24, 2011 | 08:41 PM
s_raghu77's Avatar
Even if I use the power lock on the driver left hand panel the door on the right passenger does not operate. Manually it needs to be locked and unlocked.
Do you mean to say that it is the same fuse which is giving this problem?
Old Jun 25, 2011 | 06:21 AM
Hous's Avatar
If you use the power lock on the door panel, do any doors unlock? If any of the doors unlock then its not the fuse. If you have a bad fuse none of the doors will unlock when you use the power lock switch on the door panel or the remote.
If some or all of the doors unlock/lock when you use the power lock switch on the door panel then your problem is definatly the remote (most likely the remote battery).
If only some doors unlock when you use the power locks (either the remote or door panel switch) then your probably going to have to work harder to get it fixed.
surfing07
Aug 4, 2014 05:37 AM
dwalsh77
Oct 11, 2011 07:00 AM
cinnamodori
Jun 26, 2010 10:19 AM
testdummy
Aug 12, 2008 01:47 AM
lilol89crx
Jul 29, 2004 06:56 PM
