Shifting habits -- what's yours?
Old Jan 5, 2006 | 11:09 PM
  #51
yamahaSHO's Avatar
Default RE: Shifting habits -- what's yours?
I hope you're only power shifting at the quarter mile track. Clutches and TOB's generally don't last long when using this practice.
Old Jan 5, 2006 | 11:41 PM
  #52
finalimpact's Avatar
actually 1/8 mile because im too far from a 1/4 mile track for me it has been second gear shattering, never had a rpoblem with my clutches or tob's. no biggie now i can rebuild my transmissions in 30 minutes
Old Jan 6, 2006 | 12:37 AM
  #53
amg6975's Avatar
ORIGINAL: yamahaSHO
There's no need to double clutch.
I find that the 1st gear downshift is FAR smoother and easier with a double clutch manuver. It almost won't go down into 1st without doing it. That's the only gear though, all the other ones don't need to be double clutched at all.
Old Jan 6, 2006 | 01:12 AM
  #54
neon3kgt's Avatar
i like how they shift into first after they give the go ahead.
Old Jan 6, 2006 | 08:36 PM
  #55
Seafoamgreencivic's Avatar
ORIGINAL: BallardCivic
Here comes a dumb question...
Whats double clutching?
Double clutching is pretty much what it sounds like, you push the clutch 2 times. To double clutch you would depress the clutch, switch into neutral, rev the engine trying to rev match, push the clutch again and put the car in whatever gear you are shifting to.
The whole point of it was to get a smooth shift in the old days. They didn't have syncros back in the day, so you had to get it really close because there was nothing there to try to help you.
Old Jan 6, 2006 | 10:51 PM
  #56
amg6975's Avatar
^ yeah, when you shift into neutral and then let the clutch out it gets the insides of the tranny spinning with the engine so when you shift into a gear the tranny is spinning at the right speed and doesn't have to use the synchros to spin it.
If you're not sure exactly how the inside of a manual transmittion works go on www.howstuffworks.com and look it up. Everything here will make a lot more sence.
Old Jan 6, 2006 | 11:00 PM
  #57
yamahaSHO's Avatar
ORIGINAL: amg6975
Double clutching gets the input shaft spinning the same speed (or near) as the rest of the gears that are connected directly to the differential which is being spun with by the wheels. Aside from using the engine to spin up the input shaft, you could take out the engine from the rest of the equation as you're disconnected from it when you shift.
Old Jul 22, 2007 | 11:42 AM
  #58
noshowallgo's Avatar
1st 6500 2nd 6500 3rd6500 4th6500 lmao
Old Jul 22, 2007 | 12:14 PM
  #59
Jeremy102579's Avatar
my manual gives the mph to shift at which comes out to 3k each shift for best fuel economy so that is what i try to follow.
Old Jul 22, 2007 | 12:22 PM
  #60
Sigracer10's Avatar
ya im just another average 3k to 3.5 k on daily driving.
