HCF Suggestion / Forum Help Center This section is for suggestions and help pertaining to the forum, not for help with a car.
car turns over but wont start
Old 01-15-2009, 02:10 PM
gti113's Avatar
Default car turns over but wont start
have a 97 civic and it wont start its turnin over grand but wont start i have no spark or fuel can any one help me thanks
Old 01-15-2009, 05:05 PM
When you turn the key to ON(II), does the CEL remain ON or does it turn OFF after 2 seconds?
Also check whether the important ground wire attached to the thermostat housing is loose or corroded. If so, clean with steel wool and then reattach tightly.
Old 01-15-2009, 07:47 PM
wrong section
honest question (for research purposes):
was the title of the section misleading to you?
Old 01-15-2009, 07:50 PM
Maybe a mod or admin will move the thread to the General Tech section.
Old 01-15-2009, 07:54 PM
well i'm just asking to find out
i proposed a solution (slightly altering the section's name) to this ongoing problem and kevin told me in his opinion the title of the section is fine and that newbies need to learn what section is what... well that's called circular reasoning, and you can't solve the problem like that.
OP: do you think a better name for the section would have deterred you from posting this in this section?
Old 01-15-2009, 07:57 PM
Trust, just volunteer to be a mod. Then you will likely have more influence on making site changes.
Old 01-15-2009, 08:04 PM
i volunteered
kev said the forum doesn't need anymore staff right now, and it's pretty dead around here so there's nothing to do
Old 01-15-2009, 08:09 PM
Well, I think there must be an opening for an Active Mod, which is what you'd be. The relatively Inactive Mod slots are definitely filled.
Old 01-16-2009, 11:02 AM
gti113's Avatar
the engine man light stays on but there is a green light wit a key flashs once then its off but when i turn off the key the green light flashs 5 times
RobTimmerman
10-16-2012 03:16 PM
HondaLady
01-03-2012 11:12 AM
wantacivicwagon
18
07-25-2011 02:18 PM
MuffinMan21
07-27-2008 09:08 PM
rafamofon
12-04-2007 07:02 PM
Quick Reply: car turns over but wont start
