DC-S 4-2-1 Ceramic Header. Question!!!
Old Jan 11, 2007 | 11:03 PM
StreetCivic.CoM's Avatar
Default DC-S 4-2-1 Ceramic Header. Question!!!
Ok I Have A Civic LX 99 Mostly Stock I Dont Have An Exhaust But I Bought That Header You See On the Pic I Was Wondering If I Can Install This Header Without The Exhaust Without Any Modification Or do I Need The Exhaust Or Something Else?
Thank You
[IMG]local://upfiles/17564/393208E5FF5E4E2D92904DF185318CB0.jpg[/IMG]
Old Jan 11, 2007 | 11:06 PM
Default RE: DC-S 4-2-1 Ceramic Header. Question!!!
Does It Really Add 10 To 15 HP
Old Jan 11, 2007 | 11:08 PM
my05civic's Avatar
no. it does not add 10-15. it's really like 2-3. as for fitting, give us the sizing of the header first
Old Jan 11, 2007 | 11:16 PM
this is all the info i have
[ul][*]DC-S 4-2-1 Ceramic Coated Header.[*]Made of High Quality Ceramic Coated Steel with CNC Mandrel-Bent Tubing.[*]O2 Sensor Insertion & Metal Gasket.[*]Light Weight. Add Instant Horsepower (10-15 hp).[*]Easy Direct bolt-on Installation, Require NO Modification.[/ul]
Old Jan 12, 2007 | 07:47 AM
FlipHKD720's Avatar
DC-S = DC Style Header. Off brand Ebay header. I have one, there is a little gain, some tone difference too. Your secondary o2 sensor will need to be extended, and to get your CEL off you will need to get an o2 simulator. www.o2simulator.com < if you wannna know more. Also, the flange of my stock exhaust didn't fit that of the header, so i had to bring it into a shop to get a custom flange welded on there. Real quick and cheap fix, but stillnot very convenient. I do beleive this will remove your catalytic converteras well (considernig the cat of the 99 LX/DX is right in the exhaust manifold, so this header will remove it). If you want to stay eco-friendly, get a highflow cat and have it welded somewhere in your exhaust, but if not your cat will be gone. Hopefullly you dont live in a state where they test for emissions (if you decide to leave it off). People say they crack over time, and i wouldnt doubt it, but so far mine been all good. Looks real nice too so GL with the install and eveyrthing
Old Jan 12, 2007 | 08:02 AM
so yea i rather wait for the exhaust
Old Jan 12, 2007 | 09:28 AM
FlipHKD720's Avatar
ORIGINAL: StreetCivic.CoM
....? You mean wait and get a high-flow cat? Thatd prolly be a good idea.
Old Jan 12, 2007 | 10:06 AM
D16Punk's Avatar
I'm probably the only person on here that put in a header in a DX/HX/LX (All have Cat in the exhaust manifold), did the o2 Sensor extension myself, drive around without a cat and not get a check engine light or have a smell from the exhaust because of no cat. Even when I went to get my car inspected the guys were amazed that I didn't get a check Engine light. Before I went to get my car inspected though I did have a Magnaflow High Flow cat welded onto custom piping with my Twin Loop Muffler. You can either do the header now and wait to put in the exhaust/cat on like I did or put the header and exhaust on at the same time, then have a cat welded onto the exhaust piping.
Old Jan 12, 2007 | 11:08 AM
FlipHKD720's Avatar
^ thats crazy you didnt get a CEL, i envy you man
also, you can get a highflow cat, and then a catback exhaust from a d16y8 and it will fit up perfectly (length-wise with the cat and the catback).
NonTurbo4now22
54
Jan 8, 2007 12:30 PM
mhayes2344
Aug 9, 2006 11:09 PM
Dan Sama
Aug 1, 2006 07:53 AM
fast93civic
Mar 18, 2006 01:54 PM
plc00133777
Nov 2, 2005 09:38 PM
