Header-Ceramic?
Old May 5, 2007 | 10:47 PM
Kedawei's Avatar
Default RE: Header-Ceramic?
Didn't read the responses, so if someone covered it sorry.
Ceramic coating keeps heat inside the exhaust manifold. Supposedly by keeping the heat in, exhaust gases aren't allowed to expand as quickly,resulting in less backpressure within the manifold. The concept makes sense, but on a N/A car I think the gains would be minimal. However, with the right coating, I've heard, you can touch the exhaust pipe within minutes after shutting the car down and not get burned. That might be handy, but I'm not even sure if it's true ha. I could see the coating beingmore usefulon turbo applications, assmall turbo manifolds have the potential to create a lot of backpressure, and the increased velocity of the exhaust gases through the manifoldcould help spool the turbo faster.
Old May 7, 2007 | 09:43 AM
Motor35's Avatar
Thanks y'all for the advice. I am getting my CAI anyday now. Hoping to get my header within a month.
Old May 7, 2007 | 09:54 AM
FlipHKD720's Avatar
are you in California? Megan and DC are about the same quality, and unless your in Cali and care about passing emissions, i say get the Megan.
Old May 7, 2007 | 10:11 AM
Motor35's Avatar
ORIGINAL: FlipHKD720
I am in Arizona and did hear that some of DC's header units are not approved in CA.
Thanks, Flip. I like that vinyl on your ride. Looks sweet. Is it a pain to wax around that? Who did you order it from?
Old May 7, 2007 | 10:30 AM
that guy's Avatar
ORIGINAL: mybrokenblinker
yes dc comes in stainless and ceramic, but ceramic is like 100 cheaper and there is NO noticable difference in performance.
+1
also read this thead about flip's triumph over rice
Old Jun 16, 2008 | 07:39 PM
redonred's Avatar
i got the dc sports ceramic header on my 97 civic dx and it works fine for me...of course the rust here and there...but im very happy with them....power is great
Old Jun 19, 2008 | 05:20 AM
Wyborowa's Avatar
I live in Buffalo, NY, where it's HOt n HUMID in summer, and FREEZING cold at night. Wouldn't it be wise for me to pick the stainless stell ones over ceramic, simply because i don't want to drive in the winter, heting the header up, then letting the -20 degrees wind chill crack it for me... plus, i don't think they make a header for a 08 civic LX, (NON-Si)
Old Jun 20, 2008 | 02:50 AM
powerkote's Avatar
Hi guys I have been reading your comments on ceramic coatings on headers. I must say there is no contest withceramic against stainless steel. You must go on the following web site to see wwwpowerkote.co.za.to see thehuge advantages of ceramic. Just to name a few if you coat in and outside you emmediatley get about a 70 degree temp drop on your pipes which helps with underhood tempratures There is no rust or discolourisation with heat The temp threshold on ceramic arounr 2000 derees Finally the inside coating is very smooth and assists with gas flow. check the above web site out hope you find what you are looking for! frank
NonTurbo4now22
54
Jan 8, 2007 12:30 PM
mhayes2344
Aug 9, 2006 11:09 PM
Dan Sama
Aug 1, 2006 07:53 AM
fast93civic
Mar 18, 2006 01:54 PM
plc00133777
Nov 2, 2005 09:38 PM
