help!!!!
Old Jul 7, 2009 | 11:11 AM
Dan_naD's Avatar
Unhappy help!!!!
Help nOOB here,
I have a D14a4 ej9,just recieved a d15z6 intake manifold.
As i have the week off i thought i would have a crack at the conversion myself. can anybody provide my with pics of where all pipes and sensors fit, i got most of it done, problem is when the trottle is open it kills the revs... ANY help appreciated.
Old Jul 7, 2009 | 11:27 AM
Old Jul 7, 2009 | 07:40 PM
croninc's Avatar
d14a4? huh? d16 maybe or d15?
Old Jul 8, 2009 | 12:53 AM
tankytank09's Avatar
Have you properly installed it with all the correct sensors??The manifold absolute pressure sonsor or throttle position sensor could be at fault.Or it could be an ecu problem are you using the d14 unit or the z6 unit ?,also make sure you've connected up the crank position sensor.Try a d15b7 ecu ?
Old Jul 8, 2009 | 12:57 AM
Dan_naD's Avatar
ahhh that could be it... im still using the D14 ecu!, also theres a black cylinder on the back with a sensor, what is this one??? cheers
Old Jul 8, 2009 | 01:29 AM
European.
D15Z6 actually exists too, in Europe.
So it's essentially a D16Y7 to D16Y5 manifold swap.
Old Jul 9, 2009 | 05:38 AM
Dan_naD's Avatar
ok, now it will not fire!!!! .
What could cause this considering i am working with the IM
Old Jul 9, 2009 | 01:40 PM
Unplugged injectors? Fuel line not connected to fuel rail?
Old Jul 10, 2009 | 01:13 AM
Dan_naD's Avatar
Checked that, it all seems fine (fuel lines, injectors etc.)
Any oher ideas??
Cheers
Old Jul 15, 2009 | 05:33 AM
Dan_naD's Avatar
any more suggestions? still not running and weathers getting worse
stevenc
Jun 25, 2008 09:57 AM
redridinhood
Oct 9, 2006 07:27 PM
superballa22
Sep 18, 2006 05:06 PM
coolguy1234
May 7, 2006 08:31 PM
Jas10hon
Jul 4, 2005 10:35 PM
