Help with fitment
Old Dec 9, 2007 | 07:16 PM
kyleag89's Avatar
Default Help with fitment
I want to buy an intake for my 00 d16y7. What would be the ideal upgrade to get more power out of the engine? What kind of HP should I expect to gain from an upgraded intake?
I used the search feature and i am getting confused. Will a D16y8 be an upgrade? Thanks
Old Dec 9, 2007 | 08:50 PM
civic_burns_all's Avatar
Default RE: Help with fitment
Here is the answer to your first 2 questions:
Click Me
Now for your third question:
Yes swapping to a y8 will give you a increase in hp. The y7 is a SOHC engine, and the y8 is a 16 Valve SOCH VTEC.
You should do a "mini me swap". It is where you put the y7 block and y8 head together to bolt on about 21hp gain.
Here is a the full write up and DIY that a person did on a mini me swap of d16y7 to d16y8 swap
Click Me
Old Dec 9, 2007 | 09:59 PM
FlipHKD720's Avatar
Ideal upgrade? Its different for everybodies setup. Do you want to spend less than $500 and get I/H/E, or do you want to take it a BIG step further and turbocharge your car? Its a big expensive project that will give your car some unseen downtime and that might be hard if its your DD for work or school, so i guess ideal would be up to you
Old Dec 10, 2007 | 01:19 AM
kyleag89's Avatar
Yeah I work full time and go to school at night so I was looking for a weekend project. Can I put the y8 intake on the y7 head? Or do I need to do the mini me swap? I am pretty mechanicly inclined butI think the swap is too far over my head.
Old Dec 10, 2007 | 06:09 AM
FlipHKD720's Avatar
the y8 has the side mount throttle body and the y7 has the vertical one, so no it won't fit, but you can swap over the y8 IM/TB onto the y7 and that will give you some gains, and then the y8 intake will fit. The mini-me swap will also give you some good gains as well, and its not TOO big of a project so that might be a good idea for your DD.
Old Dec 11, 2007 | 05:13 PM
kyleag89's Avatar
What does this mean? Thanks I am still a newbie
Old Dec 11, 2007 | 05:18 PM
Correct me if I am wrong
IM= Intake Manifold
TB= Throttle Body
Those seem right to fit about what flip is talking about
Old Dec 11, 2007 | 05:26 PM
kyleag89's Avatar
So if I buy a y8 IM and a y8 TB they will bolt onto my y7? Will the throttle cable hook up ok?
Old Dec 11, 2007 | 05:29 PM
kyleag89's Avatar
I have an SRI so I imagine I can attach that because the stock wouldnt fit.
roomie92
Jun 28, 2009 10:21 AM
greentea1223
Dec 13, 2007 02:10 AM
Shpadoinkle
May 17, 2005 03:55 PM
flyeyes
Dec 2, 2004 01:39 PM
civic1.5uk
Jul 14, 2004 05:21 PM
