High Flow Cat??
Old Dec 21, 2008 | 01:17 PM
Jimbo&2000SI's Avatar
Default High Flow Cat??
If i got a high flow cat for an Apexi WS2 would it fit the exhaust?
Old Dec 21, 2008 | 02:03 PM
inthezoneac's Avatar
Magnaflow High Flow Cats, the bolt on version, is a direct replacement. Which means it will fit as long as you buy the correct version. Same thing applies to a cat back exhaust.
I have magnaflow's high flow cat and the apexi ws2 exhaust, no problems experienced.
Old Dec 21, 2008 | 02:32 PM
Here's what you want: http://www.hottexhaust.com/detail.asp?PRODUCT_ID=22630
Magnaflow 22630
It's direct bolt-on replacement. Also, it's Magnaflow, so you can expect great quality and fitment. I have this (slightly different version though... mine doesn't have O2 sensor bung because my car is a 93 and only has 1 O2 sensor) and it's great.
Old Dec 21, 2008 | 07:23 PM
almost forgot, get an O2 sensor removal socket. They're around $10-$15 at napa or autozone. And get some PB blaster or something to remove stuck bolts.
Remove all bolts from cat to catback exhaust and all bolts from header to cat. Then disconnect the O2 sensor plug from underneath the car(simply pull the plug from the underside of the car), and you can remove the cat with the o2 sensor attached.
spray around the part where it's bolted, give it time to settle, remove. This is also a good time to clean the sensor where it sits inside the cat. I reused all old bolts, nuts and springs to mount the new cat.
Old Dec 22, 2008 | 09:06 AM
This leads me to another question: Does magnaflow make a good cat or should i get the megan racing one?
Also, whats the difference between a high flow cat and a test pipe?
Old Dec 22, 2008 | 09:11 AM
megan racing's "high flow cat" is a test pipe
test pipes are hollow pipes and don't do anything but join the exhaust together.
reasons not to get a test pipe:
1. it is illegal
2. your exhaust tone will be raspy
3. you will throw a CEL (check engine light
4. you will not pass inspection or smog or anything
Old Dec 22, 2008 | 09:28 AM
Thanks that clears it up for me.
So magna flow then?
And if i get one should the width of the inlet and outlet be the same as my exhaust which i think is 2.25in?
Old Dec 22, 2008 | 08:03 PM
i'm not sure about the inlet and outlet
i would imagine it's bigger than stock though since it's a high-flow cat
Old Dec 23, 2008 | 07:03 AM
FlipHKD720's Avatar
yeah you defintely dont want a cat thats smaller than your exhaust, your exhaust system is only as good as youre most restrictive part, so you'll definitely want to open it up.
dulas101
May 14, 2008 01:09 PM
Street Sniper
Mar 17, 2007 08:07 PM
StifflersMom
May 10, 2005 04:47 PM
rico892002
Jan 24, 2005 04:37 PM
02CivicEX
Jan 23, 2005 12:44 AM
