my 93 civic failed emission. need help.
Old Jul 1, 2009 | 07:04 AM
yuprety's Avatar
Default my 93 civic failed emission. need help.
i failed texas emission test due to super-high nox reading. does anyone have suggestion. here are the reading.
25 mph 15 mph
HC: 167/54 pass 173/80 pass
CO: 0.94/0.02 PASS 0.97/0.02 pass
Nox: 1240/2899 fail 1372/3036 fail
please help asap.
Old Jul 1, 2009 | 04:14 PM
hamorhead's Avatar
What mods are done to the car?
And if it has the stock engine what is it?(if you don't know just post the trim level of your car)
Old Jul 1, 2009 | 04:55 PM
Is the CEL ON?
High NOx levels indicate that the engine is running hot or lean or that the cat is bad. As your engine appears to be running lean, check the O2 sensor, the fuel pressure regulator, and the fuel pressure.
Old Jul 1, 2009 | 08:23 PM
conceptualpolymer's Avatar
Among the potential causes of non-compliant NOx readings are:
Misfire condition
Malfunctioning or improperly adjusted EGR valve
Failed oxygen sensor
Leak in exhaust tubing upstream of converter
Excessive carbon deposits in combustion chamber
Improper spark advance
Blocked coolant passage
Overly lean air-fuel mixture
Damaged cold air duct
Failed or malfunctioning catalytic converter
Corroded or damaged engine sensor electrical connections
civludeh22
Mar 29, 2008 08:53 PM
samt
Jan 29, 2008 02:31 PM
Civic Si 00
19
Jan 21, 2008 01:54 PM
m0rgansciv
Jan 18, 2008 05:39 AM
dystopia
Jul 15, 2005 02:16 AM
