Resonator
Old Sep 27, 2006 | 03:52 AM
phishy's Avatar
Default Resonator
So I bought Megan Racing Drift Spec Exhaust, it says it comes with a built in resonator. Is this just a test pipe or is it a legit resonator. I remember seeing a pic like this on the forums and someone said that it was just a test pipe. So I thought I'd just ask for confirmation, thanks. Btw this cost me 360 w/shipping & tax.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
Old Sep 27, 2006 | 08:13 AM
Default RE: Resonator
Circled in the picture is the built in resonator they are referring to. It is just part of the cat-back that helps reduce raspy noise. It's not the same thing as a test pipe, those replace your cat
Old Sep 27, 2006 | 01:02 PM
phishy's Avatar
Ya I kinda figured that part was the built in resonator, thanks for the confirmation Forty Anyone have an idea of how much this will cost to be put on @ a shop. This is a direct bolt on so it doesn't look like to much physical work will be neeeded.
Old Sep 27, 2006 | 01:20 PM
Free if you do it in your driveway It's actually a really easy install. The only think you're likely to have trouble with are the bolts holding the stock cat-back to the stock cat. If you have a die grinder or cutting wheel of any sort, it's a peice of cake.
Old Sep 27, 2006 | 01:47 PM
My04Civic's Avatar
Administrator
orrrr
1 entire can of wd-40 = smooth sailing
Old Sep 27, 2006 | 04:15 PM
TheMoogly's Avatar
Can wd-40 and simple tools do the trick?
Old Sep 28, 2006 | 09:11 AM
It should, Plus a bit of elbow grease.
FYI Die grinders are about 35 bucks at most hardware stores, and worth every penny.
Kahuna
Aug 31, 2006 11:40 PM
Toppers
Nov 24, 2005 08:33 AM
Julito
Aug 15, 2005 06:07 AM
BrennanCivic
Jul 10, 2005 06:04 PM
gunmetal
Jul 9, 2005 08:32 PM
