Diirty Engine
well i couldnt decide which area to put this in bcause it has to do with the engine, but since it has to do with the appearence of the engine i decided here would b acceptable. Basically there is 9 years of rusty wear under the hood of my 97 civic. Nothing is broken or anything but i decided if i needed to work on it 4 some reason, all this rust would b a pain to work with. so i say to myself, "well mayb bcause my car is not that new, these things happen" but i have looked at many members of the HCF's photos and id eat off of ur engines. so my question is is there anything i can do to get the rust off without having to jus take everything apart and clean it off? or should i jus start randomly painting things? or is there anything AT ALL i can do to make it look better?lol thanx 4 watever input u may have on this
ha every single part needs a shine imma paint the valve cover 2morow i think but i kno it will look like a miniscule visual upgrade in comparison to the massive amounts of rust so i was j/w if there was anything easy i could do
ya u really just gota get in there and use alot of elbo greese...scrub everything pretty hard with a damp cloth but be carefull with wires, screw, plastic stuff, and all that junk...use some kinda degresser to with scrubing stuff like the valve cover and block. for paint like the sides and such, i just wipe it clean and wax to shine it up. it takes time, greese is a bit hard to get off and there are a lota small hard to reach places too..i clean my bay about once a month, i spend about an hour just scrubbing and all.
^^ Yeah you just have to be very thorough the first time. Engine cleaner degreaser (I use simple green full strength) Lots of elbow grease and an old microfiber towel. A wire brush does well for stubborn areas on the engine block. I have different length brushes to get down deeper into the bay where you can't get your arms through the hoses and such. Clean and wax all the painted areas; firewall, suspension mounts, valve cover (if applicable) under hood etc. Armor all the hoses and plastic and you're set. Just take your time...
soldout712
Oct 30, 2006 10:13 PM
Xtreamist06
Aug 30, 2006 09:14 PM
Legend1011
Apr 22, 2006 02:30 AM
Benny Sim
Jul 19, 2005 07:43 PM
