Help!!
Old Nov 22, 2006 | 01:51 PM
ninjapimp's Avatar
Default Help!!
How do i take the passanger fender off a 99 lx civic sedan.. plz hurry
Old Nov 22, 2006 | 02:15 PM
jake11375's Avatar
Default RE: Help!!
(1) There is one fender bolt hidden beneath the sideskirt, unbolt the front of the sideskirt and pull it down to gain access to it
(2) Open your door and remove the other bolts through the fender
(3) Open your hood and remove the bolts along the top of the fender
(4) I think there may be another bolt at the front of the fender behind the headlight assembly, you may have to remove your headlight assembly to gain access to it (not sure about this one)
(5) Unscrew the front bumper from the fender (found beneath back of bumper, front of your wheel) may be a small bolt instead of screw
(6) Unscrew the wheel well rubber guard from the fender and that should get it
Someone chime in if I'm missing something...
Old Nov 22, 2006 | 02:17 PM
HARI.'s Avatar
Default RE: Help!!
pop your hood
take off the pass side headlight
take off the clips for the fender liner
unscrew all the 10mm bolts
open your door.
there's also another 10mm bolt, by the hinge.
edit: beat me to it
stevenc
Jun 25, 2008 09:57 AM
redridinhood
Oct 9, 2006 07:27 PM
superballa22
Sep 18, 2006 05:06 PM
coolguy1234
May 7, 2006 08:31 PM
Jas10hon
Jul 4, 2005 10:35 PM
